1 - 5 of 5 Posts
I have read all the missfire pages and i am stuck with with ive done. ive got an 02 wrx and ive replaced all my plugs, af sensor, and ran multiple cans of injector cleaner in my car. The missfire code doesnt show up anymore but i can still feel my car is missfiring and when i go up a hill and the car is in low rpm it starts to rock back and forth. Does anyone know what else i can do from where i am at now? i know its getting fuel but seein if anyone has had similar problems with the 2.0s??
check to see if the ignition coil is faulty, do you have good compression in the cylinder? check resistance in the injector on the problem cylinder. is that the only cylinder misfiring? Also are you getting boost problems, idle problems, driveablity problems?
The compression is good in that cylinder. and yes that is the only cylinder that is missfiring that i know of cause thats the only code that shoes is cylinder 1. How would i go about to check the resistance in the injector??
1 - 5 of 5 Posts
