I was doing a bit of research last night and was reading up on our map sensors. I found out that the stock map is only good for 24psi I was just curious if anyone could recommend any MAP sensors that would work with the 02 wrx 16bit ecu. I'm planning on making over 400+ on E85 I'm afraid that when I go to dyno the car the stock map will be limiting us to the cars full potential.
