i just bought a turbo xs manual boost controller, i was wondering if the boost spikes are a worry and if there is a way to keep a certain psi held for all my gears?? any help would be greatly apprieciated.
jonny
jonny
All quite true. Do your WRX a favor and stop using the MBC.Manual Boost controllers are not a very good way to increase boost. They add pressure (air) without increasing fuel, this leads to detonation (which is bad).
The best way to increase boost safely is to get an AccesPort from http://cobbtuning.com
Presently, fuel system hardware upgrades should not be needed with your set up.i apprieciate the help guys, i think i'll take your advice, and remove it. i do have a question though, you were saying that it would need more fuel to compensate for the air correct? what do u think i would need to compensate for it. injectors?, fuel pump?, fuel rail?
+1, A GM BCS will yeld higher PSI when tunned right.Another option would be a custom tune by somebody that knows what they are doing.
