i just installed a spt heatshield and now the MAF plug wolnt reach. has anyone had this problem with there spt intake and heatshield?
Its taken him almost a week to get the heat shield in, i don't think rewiring the MAF is a good suggestion in this case.If you can;t find another solution, just extend the maf wires.
:rotfl::rotfl::rotfl:Its taken him almost a week to get the heat shield in, i don't think rewiring the MAF is a good suggestion in this case.
hahahaha sorry i work from 7 am to 7pm. dont feel like doing it at night and i dont have a garage, the days i do have off like today its 11 degrees outside and really windy...Its taken him almost a week to get the heat shield in, i don't think rewiring the MAF is a good suggestion in this case.
WTF?! I don't even want to see what you've got going on under the hood of your car. Who decided it was a good idea to tap into your MAF?theres no way its gonna fit, i was really tight before the shield was in. now its about 3-4 inches from even touching the intake, im going to drill a hole in the heat shield to feed it threw, thats my only option, im not extending the wires cause ill just mess it up. my air/fuel ratio gauge is spliced into the wires. thats why its not reaching the plug.theres like 10 feet of eletrical tape rapped around all the wires atm but if i remember ill take some pics when i get a chance. do u think that could be the reason why my air/fuel gauge is flipping out? where should i put the wires for it?
+1.Uhm, yes.. It doesn't belong on the MAF sensor. It belongs connected to an oxygen sensor.. The MAF sensor doesn't read the air/fuel ratio.I prefer to tag the signal wire @ the ecu, for the rear oxs.
Not any more dumb than hooking it up to your MAF! :rotfl:im not sure if its just one wire or not cause i dont want to have the center gauge in my pod not lighting up it would look dumb
i didnt do it, it was on the car when i got itNot any more dumb than hooking it up to your MAF! :rotfl:
I would highly suggest you unravel the "10 feet of eletrical tape rapped around all the wires" & start over. Do it the right way, not the wrong way.
That sucks. If I were you I would get somebody who's really knowledgeable with Subaru's to look at what you've got going on under there ASAP. (If you were near me, you could come use my garage & I would help you out.) The sooner you get it all taken care of, the sooner you can fully enjoy your car & not worry about what someone else has screwed up on it. Good luck.i didnt do it, it was on the car when i got it
yea wiring isnt my strong point hahaThat sucks. If I were you I would get somebody who's really knowledgeable with Subaru's to look at what you've got going on under there ASAP. (If you were near me, you could come use my garage & I would help you out.) The sooner you get it all taken care of, the sooner you can fully enjoy your car & not worry about what someone else has screwed up on it. Good luck.
Wadda-ya mean?Da MAF reads da oxygen before it goes in der engine.It is da main oxygen sensor...Uhm, yes.. It doesn't belong on the MAF sensor. It belongs connected to an oxygen sensor.. The MAF sensor doesn't read the air/fuel ratio.
I prefer to tag the signal wire @ the ecu, for the rear oxs. The front oxs is a sort of semi-wideband or something, IIRC.
