1 - 3 of 3 Posts
Hello All,
So in my 2011 WRX wagon with 120k, I’ve got a misfire code P0301 and rough idle with roughness counts in the cylinder, will occasionally stall dropping to idle from load, especially when cold. We’ve done/checked the following:
  • all spark plugs new <15k miles
  • new MAF, cleaned
  • new injectors cyl 1 & 3
  • new coil pack cyl 1
  • seafoam through gas tank
  • dealer induction cleaning service
  • soldering in wiring harness fixed
  • ground wire near cyl 1 replaced
  • compression test good - tested multiple times over ~2-3k miles
  • leakdown test good
Next thing my shop was thinking was egr valve or intake/tgv gaskets for that cyl bank. Anyone here have any ideas? I checked the misfire pinned thread and it looks like we’ve tried just about everything. Trying to avoid engine-out or head rebuild, compression/leak down tests all being good points away from that direction.
Any help you all can provide is greatly appreciated.
Thanks!
1 - 3 of 3 Posts
