So, I have a 2013 Subaru WRX hatchback and I have been having these weird boost issues. Right now, I have the stage 2+ SF tune on it with the Cobb accessport. So I have a catless downpipe and an invidia exhaust along with the Cobb intake. I have been noticing that I'm only hitting about 13psi peak boost. I was having this same issue even with the stage 1+ tune. I have checked the throttle body to TMIC coupler and changed that out to a Mishimoto coupler. That still didn't help. I had it smoke tested, but without boost, and no one could find any leaks. I'm just not sure what else this issue could be stemming from. I'm supposed to be hitting ~18psi and I'm like 5psi away. I also like in Colorado at around 6,200ft elevation, but I don't think it would effect it that much.
I realized that this is not exact. Because the FLOW through the engine is also reduced at altitude, the engine may be able to target a higher pressure ratio. This is dependent on the compressor map (not public for the VF52). Short: the actual target MRP may be closer to 15.5 PSI compensated. Of course, there are additional compensations for IAT and ECT plus it depends on which gear you are in.
So, is the boost I'm hitting around ~14psi okay then?? Or does it seem like something else is going on?? I just switched to a higher wastegate map and pulled again last night and got to like 13.7psi
Do a log in 3rd gear 3000 RPM through 6000 RPM (be safe please) and log the following and nothing more:
1. RPM
2. Load
3. Throttle Position
4. Boost (manifold relative pressure)
5. Boost Target
6. TD Boost Error
Post the resulting CSV file here.
Also, per XJman's post -- please be clear on which map you are running (91 or 93 octane).
I read the notes for the map that I'm using and that's what it said though.
The map is 2013 SUBARU IMPREZA WRX MT STAGE 2 + SF MAP
Here is the map description verbatim:
DESCRIPTION
Stage2+SF 91 MTv331 High Waste Gate - Intended for an otherwise stock 2013 Subaru WRX MT vehicle running a turbo-back exhaust with a high-flow catalytic converter and COBB Tuning SF intake system. 91 or 92 octane fuels. Boost Targets: ~18.0psi peak boost pressure tapering down to ~13.0psi by the 7000 RPM redline, +/- 1psi. Higher wastegate duty cycle. Use if regular mapping produces less than desired boost levels.
Related Threads
Subaru WRX Forum
3.2M posts
152.7K members
Since 2001
