1 - 2 of 2 Posts
I recently installed new headlight and tail light housings. i replaced my tungsten filament turn signal bulbs ( in the front only so far) with LED bulbs. This, as you know, will cause my stock turn signal flasher to hyper-blink. I found LED compatible turn signal flashers on V-Leds.com, but it is not specific which flasher i would need to put in an 02 WRX. Anyone know which flasher i will need?
Discussion Starter #2
So I went to my locaL autozone, and discovered the stock flasher for an 02 wrx is made to be LED compatible. Saved me 8 bucks, s n h, and the delivery wait..
1 - 2 of 2 Posts
