1 - 9 of 9 Posts
I just installed a used Perrin Intake on my 09 WRX...
Current Mods include SPT CBE and stock DP.
any reason there is a little lag around 4k to 4.5 rpms? otherwise i like it and it sounds like i have a BOV installed.
Whats your guys' input?
Get it tuned, that may eliminate that. You may be feeling the ECU pulling time.
You need a tune. You may be running dangerously lean, you have detonation and the ECU is pulling timing in a desperate attempt to save your pistons from assploding. God will kill a kitten every 5 minutes until you get a tune. Think of the kittens...
+1 on the tune.
I am getting the same thing.... going to get accessport and i'll post back with results.
Buy it from perrin so it comes with the appropriate map, COBB maps don't support perrin intakes
1 - 9 of 9 Posts
