1 - 6 of 6 Posts
would anyone happen to know the reason it kinda sputters if i rev it up to pull away from a stop? or ill go up to about 3k let it go down a little and when i rev it up again it kinda skips and sputters but only if i rev it up let it go down and rev it up again while its on its way down... ? should i be worried? :sadwave:
I Drink & I Know Things
Can you get full RPMs or does it 'choke'? Does this also happen in park or just when driving? If it happens in park...could be fuel related. (pump/filter) If otherwise, then perhaps ignition-related or catalytic converter is disintegrating. I'm no mechanic...these are just past experience opinions.
i can get full RPMs yea, umm it just happens in real low rpms like cruising through a parking lot using the clutch alot for speed bumps and such, hmm well if its cat related then that may make sense, it has a catless downpipe and i think the other ones are bad.. and as for the fuel, didnt 02 wrxs have a recall for a fuel problem?
Oh alright, well thanks man I appreciate it you helped me pinpoint it because as far as I knew it was just a whole other problem that popped up because of another issue..
1 - 6 of 6 Posts
