Keep 205 or Buy STI engine
1 - 5 of 5 Posts
I have an '04 WRX. I want to continue my build, but I want to start with internals. My current EJ205 has around 118k on original motor. Should I buy and install forged internals, or just buy the STI engine that comes w/ forged?
Super Moderator
The STI engines don't have forged pistons outside of the JDM that I'm aware of.
You'll likely find buying a built block from a company like IAG to be similar in price to building what you have.
Discussion Starter · #3 ·
Oh ok. I was told they do. Should I invest in a new engine or replace the rods/pistons with forged?
Æternum
Are you aware that forged pistons will necessitate a rebuild more frequently?
All turbocharged EJ motors have forged rods and crank. The STI motor won't just drop-in. You will need a new ECU (or re-purpose an existing ECU channel) and new wiring harness to make it "work" with a 2L WRX. That's a lot of money to spend on a car that isn't worth terribly much.
If you REALLY want to spend the money on the car, the best solution IMO is the 2.1L stroker build. This involves using a 2L crankcase and a 2.5L crankshaft to increase the stroke from 75mm to 79mm. Paired with a good piston and rod combo and headwork, these motors have all the great characteristics of the 2L (willingness to rev) while spooling a turbocharger similar to the 2.5L. I wonder if anyone will do that build anymore? The 2.1L with Polyquad would have been my dream build for an older WRX.
BooSTIng
What is your end whp goal? That will tell you a lot on what type of build you need to do. I agree with zax though, upgrading to a 2.5l STi engine is more of a headache than what is worth. If your current engine isn't blown up, I would personally just have it pulled and rebuild rather than buying a whole new shortblock. But that is just my opinion. It will be much cheaper in the long run.
1 - 5 of 5 Posts
