1 - 20 of 80 Posts
Factory Short Shifter vs. Cobb Club/Kartboy
Hi, are there any opinions out there about the Cobb Club Short Shifter/bushing and Trans bracket kit or the KartBoy. Is this as good as or better than the Factory Short Shifter. I just got the go-ahead to purchase a new WRX as my new company car(I have a way Kool boss) and my initial thought was to get the factory shipper but I just saw that Cobb has one for much less. I am not opposed to doing my own installation.
Thanks in advance.
Blake in OKC
Soon to join the Club!
:) :D :)
not sure about the cobb but the kartboy has a much much shorter throw (40% i beleive) than the factory shortshifter, which i heard is not that much shorter than stock...i have felt the kartboy and if feels great, short and crisp...
i have the kartboy right now waiting for my bushings to arrive...
does this mean you can expense your mods??? ;) :p :cool:
WilliamG said:
Errr...I have the shortshift and it's AT LEAST 50% shorter throw than the standard shift.
the factory option?
sorry..i have heard that it was not that much of a difference...i stand corrected
Moderator
I had the original shifter and then after a month got the upgrade. A huge difference let me tell you. :)
when i felt the kartboy...i had to get it...
hopefully going to install it this weekend...makes spirited driving a lot more fun
I have the sti shifter and have used a very good short shift lever, ILP Performance. The ILP was shorter shifting. The Sti is smoother and less notchy feeling.
misterx
I love my STI short shifter. I have use the standard shifter and the STI and I think the STI is well worth it and much shorter.
I'm trying to decide between the two myself. I'm kinda leaning towards the factory short shifter (which is AKA the STi short shifter.) I was going to have the dealership install this (for warranty purposes) when getting my clutch checked, but they want to charge around $450. F*ck that. I'm kinda leary about doing this install myself, unless it's just bolt on. I'm really intimidated by doing anything underneith the car.
verbel...
i just looked at the cost...
the kartboy is $135...that's it...mostly because it is the shifter lever as oppossed to the entire assembly...
your call though....my .02
I did the install. It takes a bit of time, but if you have jack stands, get your wrenches and go at it. If you have small hands, you've got a huge advantage over me. I believe most of the bolts are 12mm.
misterx
PKer said:
If you get the Kartboy SS make sure you buy the bushings also.
Feels nice.
that's what everyone says...
i am going to install my shifter this weekend and do the bushings when there isn't any snow or ice on the ground...
i love the kartboy. i had it in for 2 weeks w/o the bushings, but it's better with them. the thing is great. i can't imagine paying more than double that for a short shifter. the final result is the same, and the cost is over 2X? come on, it is after all just a short shifter. plus, the ease of install with the KB FAR exceeds that of replacing an entire linkage. that's rediculous. it's just a simple geometry change...
$135 is too much. i believe mine was $100, and the bushings were $30.
dR
Yeah, But with the kartboy you just get the arm. The STI you get the whole assembly. I hear the STi is better.
And I'll only attempt the install if it comes with good instructions. I'm not very car savvy and don't want to screw anything up.
well i have to say...i have not felt an sti but i have felt dR's kartboy and it feels great...
I bought the Sti and installed myself, the stocke sucks for sure.
I am very happy with the Sti SS, my last ride being a Miata(best feel ever) says alot for the Sti SS.
I am thinking of installing the STi SS this coming spring. Did you use aftermaket bushing in the shifter? How long did it take you to install? I have jack stands, wrenchs, 30 gallon air compressor, and average skills.
1 - 20 of 80 Posts
