1 - 3 of 3 Posts
is hte heat shield necessary? its a ***** to get back in there...... i plan on wrapping my dp and uppipe in hte next week or two so will i be ok without the heat shield or do i need to get it in there?
Although a heatshield isn't necessary it is just another good way to reduce heat soak on the TMIC... You'll be fine if you choose not to reinstall it
SuperNova
You can trim the heat shield to fit. The lower part wont ever bolt up again, but the top part is most important.
1 - 3 of 3 Posts
