1 - 3 of 3 Posts
My GC got totalled, and it needs a new subframe. I asked this question in my local forum but figured some of you guys here would know too. I'm looking for a front clip off of a JDM GC, figured if i'm gonna spend $5K on fixing it, might as well do the motor and all. So, do they swap or is there a difference? I'm assuming not, but I'd rather make sure.
Thanks!
Irena
Moderating on the run!
I was under the impression that the GC (both USDM/JDM) did not come w/ a subframe.
Are you talking about the front cross member? If so the JDM one won't fit- they used a different front cross member to accomodate the turbo bits. If you get the entire front clip it might work- ie control arms/sway bar/links etc.
Big Sky
1 - 3 of 3 Posts
