Hi,
So I ordered a used EJ205 with AVCS from JDMRacingMotors and I also ordered the JDM ECU and engine harness with it. My throttle body would not bolt onto the JDM intake so I swapped the upper intake manifold from my old engine onto this one.
The problem i’m having is I do not have any connectors on the JDM engine harness that will match my TPMS, IAC, and the other sensor on the throttle body. Do any of you know the pin out for this 6 wire connector? I assume I should be able to repin it so that it will work. Or do you have any other ideas? I have a feeling this engine came out of a forester that used a different style throttle body.
Pictures-
Album — Postimages
Pictures-
Album — Postimages
