1 - 20 of 27 Posts
Please take a look at this video and tell me what you think.
I've checked my car for vacuum leaks using carb cleaner, and found nothing. Also a smoke test was performed at a tune shop and they found no leaks either.
I know this is a cheapo gauge but my autometer boost gauge shows the same thing.
When I first start the car the vacuum goes to -21 and stays there relatively steady however if i give it some gas it will jump down to -24 and then hover around -18.
I would love to know your opinions on this.
Let's start with whether you car is running correctly. I'm not clear why you're posting this. Is it just because of the readings you're getting on the gauge?
I don't see what the problem is here other than that appears to be a really crappy gauge that doesn't work very well.
What modifications are performed on the car? Full list as well as your method of tuning would be a good start. As for how the vacuum is behaving I don't see a whole lot wrong with it.
The car runs fine when it is warmed up. However on a cold start the idle is very rough almost like a misfire..
start with the basics. If there is no leak and your having a rough idle then clean your maf with maf cleaner. After you do that, reset the ecu and see how it responds
Also, are you really running a stock downpipe? or did you just forget to mention that?
Any reason for upgrading so many parts and not the one that for the money probably has the biggest power increase?
Discussion Starter #11
I purchased the car modded. I believe the dp is stock, as it looks stock.. Only performance mod i did was get the dyno tune.
I don't understand why somebody would do those mods and not do a DP...
neither do I. Leads me to believe there may be some other out of place or strange modifications. How much hp did the car put down?
Well it seems like it actually does still have the vf34 (yes I'm serious about this, I've seen multiple people put back the stock turbo and sell it claiming its still the vf). Honestly your vacuum doesn't seem that strange to me.
Its really not drifting that much. It moved once and then stayed within 1psi, thats nothing. Is this on a cold start, warm start, immediately after driving?
Æternum
I was expecting a Eureka or Dyson...
1 - 20 of 27 Posts
