1 - 18 of 18 Posts
Pix of IPR TMIC in 2011 wrx.
Installation took about 3 hr. used the Tomioka Racing Throttle Body Hose,
T-Bolt Hose Clamps and some longer bolts for the turbo. The IC fits very tight but for $435 i think its worth it.
Where'd you pick it all up from?
The fin density of that I/C looks awful in those pictures.
Ok, here is the deal!!
After long hours of tuning there wasn't a lot of gains:(
So If you get aftermarket TMIC you must modify your air scoop.
Before
and after
Pro Manscaper
Looks good...but as they said...the fin density is rather meh...so you won't have much improved area to dissipate heat. That and it's pretty obvious that you need to modify the splitter/scoop to adequately flow air through a different sized/shaped intercooler in order for it to work as intended.
What are your other mods OP?
Discussion Starter #9
Now I'm running custom stage 3 map @ 20psi with 10.8 AFR
but the car feels stronger then a protune map 311WHP 352 TORQUE @19 PSI 93 with stock TMIC
My other mods:
AP, K&N typhoon intake, Turboxs bypass valve
IPR TMIC, Invidia Q300 Exhaust
3" Tsudo Stainless Bellmouth Downpipe
GrimmSpeed Electric Boost Solenoid
Discussion Starter #10
How much gain did you see?
Do you know the dimensions?
The new TMIC is 11x10.8x4 inches Its about 200% over stock, the gains are around 1.5 degree of timing (still tuning). The stock would be just fine but it blew up @ 19 psi
Pro Manscaper
Well at least this will provide you a good piece of mind if you decide to go further with turbo swapping.
Question though...what makes it Stage 3? Still looks like Stage 2 to me...
Gold Member
Beat me to it.
Also, are you able to shut your hood okay with that BPV on there? I have the PW TMIC, and I had to get a more low-profile BPV.
Discussion Starter #13 (Edited)
Finally I got some numbers
timing with stock IC stage 2 protuned and customized TP stage 3 map with irp IC (WOT)
Here is virtual dyno of two runs, stage 2 protuned and customized TP stage 3 map
Stage 2 dyno was 311whp and 352 wtq, the virtual dyno showed like 298hp so i bumped the weight to match the 311hp
Discussion Starter #16
where did u get the stage 3 map?
also ur no longer fmic? your IPR tmic?
im almost same set up with you but i have tomei uel header and process west tmic and forge bpv
im making close to your power but on 91 oct and 19.6 psi
Discussion Starter #18
I got the map from Eric @ TP
Now Im running FMIC, the IRP is worst than the stock IC. 311HP was with the IRP IC and after I install the FMIC with Eric's map the car is a lot faster. Also I ported the turbo because I was getting boost creep and did some adjustments to the map. Make sure U got AFR Gage. Good luck :)
1 - 18 of 18 Posts
