1 - 3 of 3 Posts
My friend and I are going to be installing my 3" TBE tomorrow....just wanted to know if there was any little things I should know before we attack this project, bacause I will be needing my car to drive to work the next day. I have the gaskets and all necessary bolts so I'm straight w/hardware..so any advice would be helpful before the install thanks. Also for those of you that installed tbe on your own..what was the estimated time of the install?Thanks!!
Make sure you spray everything with Liquid Wrench...especially since its cold and bolts will tend to snap. Also spray it in the exhaust hangers so its easier to slide the exhaust out of them.
Do we need new bolts to go from the DP flange to the turbo?
1 - 3 of 3 Posts
