After extensive R&D Fine Line Imports is proud to introduce the first in their line of high performance Subaru motors. All Fine Line Imports motors are designed for maximum reliability and power handling while minimizing piston start up slap.
EJ25 "STI" Semi-closed Block (2.5L Displacement)
FLI closed decking process
Supertech / FLI forged pistons 100mm (8.2:1 compression ratio)
Billet Steel (4340) I-beam Connecting Rods
STI Forged Chromoly Crankshaft (79mm Stroke)
Professionally coated Rod and Main bearings
Heavy-Duty Chromoly Piston Pins
If you have any questions please let me know.
Ryan
Fine Line Imports
FLI STAGE 3 SHORT BLOCK
Ryan
Fine Line Imports
