1 - 20 of 24 Posts
What size turbo?
its just a stock turbo running 18 psi, alott of people are telling me to leave it bbut i wanna upgrade, but a buddy of mine says i need to change my intercooler before i really do anything
You need to find out what your goal is for the car first, otherwise you are spinning yur wheels (spending $ aimlessly).
Find what turbo you want and can support, then the question can be answered.
Sammich Makin' Pwincess
a FMIC with that set up is definitely not good use of your money.
you should get:
turboback exhaust
uppipe
tune.
if you want a FMIC, a bigger turbo & supporting mods would be the best route to take with that.
A stock turbo doesn't even come close to warranting a FMIC. You will more negatives to performance than positive.
Get an stock STI TMIC if you must, but your stock intercooler is fine for what you have.
UnBanned
If you plan to get a bigger turbo... then it doesn't hurt to look at upgrading to a fmic (in my opinion) My personal opinion is, vf39 and larger can rate a medium size fmic.
I'd look at the Perrin piece... it's 18% off right now, and it's one of the better FMICs on the market. The Perrin, and APS DR525 are the only two FMICs I'd recommend anyone look at.
Discussion Starter #11
i want torque and alot of it
moy said:
i have all those i have headers up pipe n down as well as being tuned also
Look into an EvoIII 16G turbo setup - that'll do more for you than a FMIC
i just bought a evo 3 big 16g cant wait to get it.. do u think that sti TMIC is ok for that turbo.. i was looking at FMIC kits but they look like they go through the hole i have my intake in on my pass. side fender.. i have the APS 70mm intake.
The APS FMIC works with their intake.
The STi TMIC would be fine, but if you can find a used TXS TMIC (not one of the chinese knockoffs), that would be better
1 - 20 of 24 Posts
