1 - 4 of 4 Posts
For starters, this applies to a 2002 2.5 RS.
I you look at the intake pipe leading up to the airbox, there are three pieces coming down from it, I went ahead and pulled them off and capped the holes. I drilled a small hole in each of the caps so as not to create a vaccuum. It gives the intake a really good sound, and probably a bit more air. I was wondering if anyone is aware of this potentially causing a problem.
thanks in advance
--Eric
1 - 4 of 4 Posts
