I have a 2015 WRX I bought about a month ago. It was running an AEM intake and what I can only assume was the OEM tune. I don't know because I don't have any documentation of the vehicle afterwards. The Dealership did a check on the vehicle when they got it and it passed their checks (Whatever that might mean to the reader of this).
After looking at the vehicle myself on a lift I can see they put on the STP (STI) Catback. The downpipe appears to be OEM as it has the giant cat shielding on it.
I have since taken off the AEM intake and replaced it with the Cobb Big SF intake and had flashed it with the appropriate Stage 1+ BigSF 91 tune. 91 is the most common in my area so thats what I use. There is only 1 gas station within a 50 mile radius that has a 93 pump. After putting this 91 tune on I got about 1 mile before my DAM dropped to 0.6 under a moderate pull and continued to drop over time. I read on Cobb's site that it might benefit to run the LWG version of the Stage1+ tune so thats what I ran for about 1-2 weeks. The Dam still dropped but it bounced between 0.4 and 0.8 until it finally settled at 0.412 for a few days, then dropped to 0.312, then just yesterday dropped to 0.188. No CEL, the car never stuttered and didn't have any knocking at idle. I'm an idiot and unfortunately did not datalog the times where the DAM was dropping. I have since reflashed the ECU with the normal wastegate cycle for the Cobb BigSF 91 Stage1+ tune that comes on the AP. Casual driving under minimal boost (At most 4 PSI) and the DAM never dropped. It wasn't until today when curiosity struck and I did a short pull on my way back from lunch where I started logging before I did the pull. It wasn't by any means full throttle, just enough to feel the car pull.
Heres the log
Notes to consider:
Performance related Mods:
Cobb Big SF Intake
STP (STI) Catback
Thank you in advance for any help.
Heres the log
Notes to consider:
- The original bracket that Cobb says to use with the new model of the BIG SF intake, I didn't have so that part essentially just floats with the box cover and the box secured together with the Alan screw they provide.
- I cant remember but I will check tonight if I put the silicone tube from the intake to far over the OEM inlet piping as shown in this image on Cobb's Docs for install
- The car currently sits at 79,700ish miles. The last oil change was at 77,900ish miles. As stated earlier the Subaru dealership I bought the car from did not give me any maintenance documentation of the vehicle so I pulled the coil packs and spark plugs on the driver side and inspected them for ware. The Spark plugs had very minimal and normal ware so I assume that side was changed recently. I did not change the passenger side yet.
- A few weeks ago when I did the first oil change, I did not prime the system and over filled the pan. After driving around a bit the oil cap blew off and I had to get a replacement. Oil sprayed all over the driver side of the engine bay and was a mess to clean up. Its still not all cleaned up but the majority of it is gone. I disconnected the battery and cleaned everything I could with soapy wooder as that was all I was comfortable using at the time.
- This car is my Daily.
Cobb Big SF Intake
STP (STI) Catback
