1 - 11 of 11 Posts
Any one know how to fix or troubleshoot indicator light error on dashboard?
I got a pair of new headlights and I'm getting the indicator light. Looked all over the web and can't figure out how to remove or if it is even possible to flash.
Any ideas?
Discussion Starter · #6 ·
I got into an accident with a truck and I busted the right passenger headlight. Ended up selling the single and replaced Both with aftermarket.
Discussion Starter · #7 ·
Any harnesses or adapters to flash the error? The look and design is similar to the OEM but not sure if the wires are cooperating with the electrical system
Super Moderator
Only the headlight and no other damage im going to say it's not the dash it's the headlight. You will have to have Subarus tool to read it i believe
Discussion Starter · #9 ·
Yeah, I was thinking they might be able to flash it with some tool that they have.
Might have to take it in to have them look at it
Super Moderator
Flash what? There is nothing to flash. It's telling you there is a problem with the voltage or amperage or something.
Discussion Starter · #11 ·
I'll probably end up just taking it in. Did enough research and can't really find much besides just bringing it in to the dealership
1 - 11 of 11 Posts
