So, I'm driving off after I installed my Invidia catless dp and I'm fine for like a half mile or so then I decided to WOT it and I hear the blow off valve go off louder than usual and my engine is cut off. I looked and I have 14.5psi which is the highest I've seen it run before. I restarted it and it was on but it was rough when it was running and had no control of the throttle at all. I have a Cobb AP and just tuned it to stage 2. Took some forums words for it and thought it'd be alright to run it and never had a check engine light at all for not having a cat.
From what I read about boost creep is that your fuel gets cut off too as a safety so you don't blow your engine.
Can I just reset my ECU and just not enter high boost and still drive it? and what solutions are there to eliminate boost creep?
