Yup, those are STi trunk springs, get them from fastwrx or dealer or whoever depending on shipping. For waterproofing, you can buy the oem sealant from dealer. Any holes you drill won't have e-coat on them so the sealant is doubly important.![]()
Upgraded Trunk Spring Kit 2015-2021 WRX/STI Sedan
Includes two higher-strength torsion bars (trunk springs) to handle the additional weight of the STI wing. Use when adding an STI wing to a WRX, or to a previously wingless STI. Fits all 2015-2021 Subaru WRX/STI sedan.www.fastwrx.com
is this more or less what I’m looking for?
It's not a problem on stock cars, otherwise subaru would be dealing with a lot of shit related to emissions system warranty. It can be a sign that you are running lean.View attachment 334721
Put my Grimmspeed j pipe on over the weekend. Decided to do an E tune till my pro tuner can get caught up. Day 2 of driving I got a rear O2 sensor low voltage CE code. I cleared the code and it seems to randomly come back on during normal driving conditions. I’ve done a lot of reading on this since and it seems to happen a lot with our cars stock or modified. Other than checking to make sure the wires or pins aren’t visibly damaged does anyone have any tips for what I can check for prior to just replacing it?
I read that as well, I’ve sent logs to the tuner and he said it was a bad sensorIt can be a sign that you are running lean.
Mine pops up about 1/2 inch like you indicated. It should be easy to open with gravity taking over at about 50 degrees of trunk opening.What’s normal for you STI guys?
Stages differ by manufacturer. What exactly did you reflash?Replaced my 02 sensor earlier this week and re-flashed my ecu. I was a little underwhelmed with the power difference of the stage 2 or 3 (whatever you wanna call it) but my car feels noticeably faster now. I thought the post cat sensor did not reduce performance but when I do third gear pulls I now have an additional 2 pounds of boost on the same revision.
On the accessport I did a reset of the ECU. To reset learning.Stages differ by manufacturer. What exactly did you reflash?
