1 - 9 of 9 Posts
Yes it can be made to fit. 2015 ej257 really isnt much different than a 2011 ej257 as found in the 2011 hatch STi.
Æternum
I would install an OEM longblock.
What's wrong with your existing motor?
Discussion Starter · #5 ·
Zax,
I was racing my friend and I hit 3rd gear already red lining and I was ready for he next gear but I accidentally shift back into 2nd gear and the engine blown. I mean like at first it had a rod knock but I couldn’t tow it because I live on hawaii I drove it all the way home. And now it’s bad ticking like shaking nails in a box. But we are going to get a new engine perhaps the same ej255
Æternum
Zax,
If you are installing a full longblock, go with the EJ255.
If not, have the block disassembled and figure out what was damaged.
Super Moderator
Why would you need axles? I’m confused as to that line of thought.
You’ve got multiple options. All of them extremely expensive. So your cheapest is probably buying a used long block then having the block rebuilt and the heads machines followed by new shortblock and rebuilt heads.
1 - 9 of 9 Posts
