1 - 6 of 6 Posts
i have a 2002 wrx.with the 2.5 block. i have 820cc injectors with a flashed ecu. i am getting a code bank 1 is running lead.any idea of what i need to do to to fix this problem .thanks
In Memoriam
In order:
-dirty maf
-post-maf vacuum leak
-piss poor tune
-bad o2 sensor
who tuned it? When was the last time it didn't have this code?
altenator connection was loose
the positive connection was loose.so i cleared the code and tighten the altenator connection.for the moment the check engine light is off. tomorrow i will see if it comes back.and will also check foe leaks.
P0171 may not come back immediately. The car will have to cycle and you'll have to be under vacuum if memory serves. It may be a while.
Or any leak in the intake between the MAF and turbo.
1 - 6 of 6 Posts
