Status
Not open for further replies.
If you do not currently have HIDs from the factory, please read the following for information why "HID kits" are not suitable:
Daniel Stern Lighting Consultancy and Supply
For the 2002-2003 WRX, you've got the following bulbs in your car...
Lows: 9007
Highs: 9007
For the 9007, your best bet is buying a proper bulb:
Amazon.com: Philips 9007 X-treme Power Headlight Bulb, Pack of 2: Automotive
For the 2004-2005 WRX, you the following bulbs in your car...
Lows: H1
Highs: 9005
For the lows, your best bet is buying a proper bulb:
Amazon.com: OSRAM - Night Breaker Unlimited H1 (Pair): Automotive
9005 to HIR:
HIR bulb base modification
Buy these bulbs:
Philips 9011 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive
For the 2006-2007 WRX, you've got the following bulbs in your car...
Lows: H7
Highs: 9005
Philips X-treme Vision H7 12 V, 55 W Headlight Bulbs (Pack of 2) : Amazon.com : Automotive
9005 to HIR:
Buy these bulbs:
For the 2008+ WRX, you've got the following bulbs in your car...
Lows: H11
Highs: 9005
H11 to H9 modification:
H11 to H9 conversion. DIY with temps - NASIOC
Buy these bulbs:
Amazon.com: Philips H9 Standard Headlight Bulb, Pack of 1: Automotive
9005 to HIR:
Buy these bulbs:
For the 2004-2005 WRX STI, you've got the following bulbs in your car...
Lows: D2R
Highs: 9005
For the lows, there isn't really an upgrade available. Purchase the following bulbs if you need replacements:
Amazon.com: Philips D2R Xenon HID Headlight Bulb (Pack of 1)
9005 to HIR:
Buy these bulbs:
For the 2006-2014 WRX STI, you've got the following bulbs in your car...
Lows: D2S
Highs: 9005
Amazon.com: Philips D2S Xenon HID Headlight Bulb (Pack of 1)
9005 to HIR:
Buy these bulbs:
For the 2015+ STI, you've got the following bulbs in your car...
Lows: LED
Highs: 9005
9005 to HIR:
Buy these bulbs:
NOTE: Recommendations are based on OE bulb used, not high vs low or WRX vs STI model (e.g., if your car uses 9005 bulbs, it will be the same recommendation of HIR mod, high/low beam or WRX/STI). This thread may not always be up-to-date on what models use what bulb, so before blindly purchasing upgrades, verify the bulb information listed is correct. If the information is not correct, create a new thread in this section outlining the OE bulb size used, and request advice. If I find the information to be outdated, I will reply to your thread, and include an update in here.
Status
