1 - 18 of 18 Posts
yep needle nose tweezers work great,
just dont use a rag to wipe them off, you will end up bending those IC vents in a second!!!!!
Bah....bug dry and crack quickly when they die....they'll eventually just fly away as dust, or get washed out with your repeated IC spraying.:D
Try using a vacuum cleaner with the curtain attatchment (has a soft brush material surrounding the suction hole. Should work pretty well I think...
If you've never fiddled with the fins on your intercooler, you have no idea how soft the aluminum is. It is exceptionally soft.
A pressure washer would destroy the intercooler. I use water and a soft brush.
misterx
same, but different....
I'm interested in cleaning my intercooler, but not of bugs or leaves, ect.
I seem to have this blackish film that has been "growing" on my intercooler and I'm not sure what to clean it with. If I wipe my finger along the edges (the lip, not the fins) the stuff is almost like a stiff grease that's gotten dirty. As for the fins, I can't figure out what the "black stuff" is or what I should use to get it off. I've got some cirtus degreaser, but don't know if I should be spraying in on. Here are some pics of what i'm dealing with. Thanks for any input!
one last one. You can see the smeared (sp?) part on the right
:confused: Thanks dude
When I used to own my motocross bike I had a metal pick set that I used to fix the fins on the radiator. It worked great and allowed me to fix any bent fins...I think I'm going to be getting a new set for my subie.
I've had the exact same thing except mine is a more even and smaller semicircle, only about 3 inches down on the right side and 2 inches down on the left side. I noticed it the day I got home from the dealer. Now mine is darker from winter road crap. I now also have a few pieces of sand/rocks in it. Anybody know if all-purpose cleaner or Simple Green is ok to use?
i've seen screen for the scoop on ebay, might be worth the couple of bucks in relation to damaging the fins
Moderator
excuse me, but my DIY intercooler sprayer is made by Super Soaker ;)
i have two of those bottles mounted in the trunk :D
1 - 18 of 18 Posts
