1 - 13 of 13 Posts
I've heard the same # over at i-club but don't know the source. I've never worked on a factory turbocharged vehicle but it sounds like a fair amount of time to let it set in...
That being said - I'd find it hard not to dip into the boost for 500 miles. :D
Discussion Starter · #9 ·
WizardBlackWRX said:
Just to totally change the topic... How is that turbo anyway? When does boost hit? And what turbo did you have last to compare it to?
Oh and how is the Quantum Racing Stage 2 Throttle Body with Coolant Bypass? I was thinking of the stage 2.
Or you could just PM me back with the answers if you want.
No problem. :)
The turbo is going to vary with the system you have. I have a TEC3 and can spool it a little faster. I am still taking it easy, so I am not sure when it'll hit. It should pump out more than a VF22. It all depends on the wheels and housings you use, though. I am using a smallish Garrett and it is rated a bit above 400 I believe (at peak).
The stage 2 is pretty nice. Everyone seems to like it. The bypass portion is a DIY, though.
To be honest, Stage I should offer about 90% of the Stage II benefits, so I would opt for that one, but then again, if you're gonna have it done...
Turbo Break in
Just install a VF 22 Turbo, my question is do I have a break in period on the turbo???
I know many people let the turbo get lubricated for a few hundred miles ....
Jose
1 - 13 of 13 Posts
