1 - 4 of 4 Posts
When I was reassembling the car after installing the turbo back exhaust I absolutely could not figure out how to get the lower turbo heat shield back on. I ended up just leaving it off. Is that going to cause any problems? The upper heat shield went back on fine. Is the part meant to keep you from touching a hot turbo or to hold down the temps in the engine compartment?
1 - 4 of 4 Posts
