I have a 2015 WRX limited with the turn signal and fog light down low on the front plastic bezel.
I have aftermarket headlights now that have the turn signal built into the headlight’s c-light and I don’t need the turn signal from the bezel. As it is now, the c-light and lower turn signal flash at the same time. I’m retarded when it comes to wiring so what’s the simplest way for me to disable the lower turn signals without: losing my fog lights, throwing a code, or causing my headlight turn signal to rapid blink signaling a bulb is out?
Thanks
Thanks
