1 - 8 of 8 Posts
Hello, I am adding driving lights to a bugeye.
I want to wire them so that the HIGH (main) beam triggers the driving lights.
I *think* both leads must go through the relay bc of Subaru’s earth switching setup. There used to be a diagram.
Anyone have a schematic?
Thanks!
Discussion Starter · #3 · (Edited)
Sorry, can't help with a bugeye schematic. But what is this "earth switching" setup???? Never heard of such a thing. Am curious what it is......
The bugeye models including the WRX and the STi RA Spec C use a halogen HB5 lamp bulb (correction: there is market-specific H4 also but it's still a single 3-prong bulb). There is one bulb per headlight and it has two filaments, one for dipped (low) and one for main (high) beam.
When the main beam is on and I connect a test lead to the battery, there is a wire on the harness that has earth and the other two have a live circuit. So I think both filaments are constantly connected to the positive side of the battery and the car switches earth.
If so, and unless I'm hallucinating, this means that to set up a relay and have the switch in the car act as a master for the driving lights, only allowing the driving lights to be on with the main/high beam on the stalk, then I'd have to do:
+ side from high beam connector on car to power on driving light switch (my trigger)
+ output from driving light switch to 85
earth from high beam connector on car to 86
+ from battery to 30
+ output from 87a to driving lamps
and then make a connection from the driving lamps to the chassis to complete their circuit.
That's my plan. I *think* I need to run both wires from the car's headlight high beam harness to the relay (with the + running through the switch) or else I won't be able to use the stalk to control the lamps. After staring at something EJ257 kindly shared and making faces as if I understood it (who am I fooling?) I also *think* I need a diode to prevent back current through the DRLs.
Anybody confirm:
(a) my general scheme above
(b) whether I need a diode and if so, what value (I know this is an empirical question but I don't know from circuits).
(c) the the "central" wire on the car's headlamp harness (at the bulb connection) is COMMON + for both filaments, and the other two are switched?
(d) when I stare at the lamp connector on the car's harness, the LEFT side is high beam +?
Thanks!
Water.....sometimes waves
I love these kinds of challenges. BUT they are hard to solve with words, on a screen. I would need a sketch of what u found at minimum. And when you say one earth and 2 hots with the mains on, is that with everything connected up pr are u checking with the connector unplugged from the bulb?
If u have time we can figure this out.
Discussion Starter · #5 ·
Thanks!
Hemingway write time is the one thing we have not of.
I do have EJ’s diagram (thanks again!) and this weekend my work (and working!) is cut out for me!
I’ll update.
Discussion Starter · #6 ·
I *think* I need a diode to keep the high beam indicator on the dash and the DRLs working correctly?
If so, where, and in which orientation?
So, if in the first diagram those wires from the switch to the high beam bulb are tapped/spliced into the existing wires with no original connections changed, this will work just as u have it. No diode needed.
Furthermore, the positive (hot) wire to that switch can come from any 12v source - it doesn't have to be from the high beam hot. The high beam's - (ground) will control things regardless of hot source for your new lights.
This is all if the oem wiring is what the 2nd schematic shows.
Discussion Starter · #8 ·
Thanks!!
I’ll give it a go and see what happens.
1 - 8 of 8 Posts
