OK. This doesn't mean much without an explanation of the baseline run and list of modifications.
EDIT: For those interested...
http://www.clubwrx.net/forums/new-member-hangout/134584418-2017-wrx-10k-miles-mod-list.html
Date Activity Quantity Rate Amount
03/15/2017
03/15/2017
090070 Grimmspeed Intercooler 2015+ wrx
1 849 849.00
03/15/2017
090113 Grimmspeed Charge Pipe
1 245 245.00
03/15/2017
Grimmspeed Electronic Boost Control Solenoid 3-Port - 2015+ WRX/FA20
1 149.59 149.59
03/15/2017
Dyno Tune
1 850 850.00
03/15/2017
Shop Supplies
1 46.5 46.50
03/15/2017
Kartboy cable shift lock - Subaru
1 32 32.00
03/15/2017
TiC 2015 WRX shifter bearing
1 15 15.00
03/15/2017
Turn in Concepts Tranny Crossmember Bushings
1 35 35.00
03/15/2017
TIC 2015 WRX TGV Deletes
1 95 95.00
03/15/2017
EGR Delete
1 50 50.00
03/15/2017
324600 FADIT Flex Fuel Kit
1 600 600.00
03/15/2017
DW9-651-1010 DW65C Pump with BRZ Install Kit
1 149 149.00
03/15/2017
FaWRTSH_EWG Killer B TWIN SCROLL 321 STAINLESS WRX FA20 HEADER EWG
1 1946 1946.00
03/15/2017
Invidia Q300 Cat Back Exhaust Stainless Tips Subaru WRX / STI 2015
1 1027 1027.00
03/15/2017
Make Cobb exhaust 3" at back
Flange and pipe $50
1 175 175.00
03/15/2017
Silicon Vacuum Tube Foot 5/32
7 1.5 10.50
03/15/2017
Pitch Stop Brace for 2015-17 WRX/STI
1 280 280.00
03/15/2017
Subtotal
6953.59
03/15/2017
Intake Install
- customer has
1 120 120.00
03/15/2017
Intercooler Install
1 180 180.00
03/15/2017
EBCS install
1 120 120.00
03/15/2017
Charge pipe install
1 120 120.00
03/15/2017
Rear Sway Bar install
- bar and links from customer
1 120 120.00
03/15/2017
Pitch stop install
- customer has
1 30 30.00
03/15/2017
Shifter Install
- customer has trans trans mount
1 150 150.00
03/15/2017
Catback Install
1 120 120.00
03/15/2017
Header Install with J pipe
1 360 360.00
03/15/2017
Fuel Pump Install
1 180 180.00
03/15/2017
TGV/EGR Install
1 240 240.00
03/15/2017
J pipe Install
- customer has
1 295 295.00
03/15/2017
Subtotal
2035.00
03/15/2017
PSP-DRV-052 FA20DIT Engine Mount Set
1 369 369.00
03/15/2017
Labor
- Install Perrin motor mounts
3 120 360.00
03/15/2017
Install Flex Fuel
1 120 120.00
03/15/2017
W63414 - Whiteline Plus 12+ Subaru BRZ / 12+ Scion FR-S / 12+ Toyota 86 Rear Trailing Arm - Lwr Front
1 79.8 79.80
03/15/2017
kdt938 Rear Subframe Insert Bushings
1 39.8 39.80
03/15/2017
Bushing Installation
1 260 260.00
03/15/2017
RCE-15wrx-yellow
1 359 359.00
03/15/2017
Spring Install
1 395 395.00
03/15/2017
Labor - Alignment
1 165 165.00
03/15/2017
spc 67660 Rear Adjustable Control Arm
2 125 250.00
03/15/2017
Control Arm Install
1 80 80.00
03/15/2017
Front Lip
1 149 149.00
03/15/2017
Front Lip Install
1 120 120.00
03/15/2017
w63225 Rear Control arm - upper inner bushing
1 159 159.00
03/15/2017
w61923 Rear Trailing Arm Bushing
1 59.8 59.80
03/15/2017
1 400 400.00
03/15/2017
Whiteline Roll Center Adjuster
1 249.8 249.80
03/15/2017
Roll Center Kit Install
1 120 120.00
03/15/2017
IAG-ENG-7252 IAG AOS Street Series 2015+ wrx BLACK
1 419.99 419.99
03/15/2017
AOS Installation
1 350 350.00
03/15/2017
Install Duck bill trunk lip
1 120 120.00
