1 - 5 of 5 Posts
P1130 Front oxygen sensor circuit malfunction (open circuit)
sounds like a bad connection, or bad o2 sensor.
K do you know how i would be able to check for a bad connection. How do i know if my o2 sensor is bad?
well for a connection safely jack up the car and put it on stands. check the wires around the sensor ( located in the downpipe) and follow the wire to the harness. As far as if it is faulty a scan tool could give the answer to that
1 - 5 of 5 Posts
