1 - 2 of 2 Posts
could someone tell me the difference between the STi rear brakes and the wrx?
what is the difference, if any, between the rotor diameter? Calipers?
thanks
ClubWRX.net Vendor
The rear rotors for the STI are much bigger.
-Outside Diameter = 315mm
-Height = 67.5mm
-Bolt Pattern = 5-100
I believe that the rear rotors for the standard WRX are about 10.3".
PM me if you need to purchase the rotors for either vehicle. I can get you really good prices, because I machine the rotors myself. I can provide you with cross-drilled or slotted rotors.
1 - 2 of 2 Posts
