1 - 5 of 5 Posts
Hey. Im in the process of taking off the stock exhaust to install my turboxs. I took off the stock system except for the downpipe. The two bolts on the bottom are really hard to reach. Anyone have any suggestions as to how to go about taking those off? should i take the intercooler off? or is there an easier way to reach them.
Are you on ramps or a jack stand?
im on ramps. I actually got it off. but now the problem is this:
the stock exhaust system has one obd sensor. The turboxs system has two holes for sensors and the directions say to install the second one as well. Which hole should i fill with a bung? the one after the downpipe or the one after the cat? im assuming the after the cat...
Pro Manscaper
Easiest to get to the bottom bolts from under the car, be prepared with a breaker bar and some spare bolts:rotfl:
Compare the locations to the stock DP and put the O2 sensor in whichever one is closest to the stock one:cool:
Edit...the 02 sensor is supposed to go after the cat. So plug the hole closest to the turbo.
1 - 5 of 5 Posts
