Hey everyone, new to the forum, my names Ryan. Not sure if this is the right area, but if not, hopefully someone can direct me.
I Recently bought a 2017 WRX (first one I own) and I'm having an issue with my Accessport. Hoping someone from this community might be able to help me out. https://www.youtube.com/watch?v=kpHMvYpdSHISo I purchased a Cobb Accessport 2 days ago, brand new from a retailer in the GTA area. I got the Cobb Big SF Intake with it aswell and was able to flash the OTS Stage1+ map to my car, so at least there's that.
Now the issue I'm having is tricky to explain, but the AP cannot stay connected to my vehicle. I've done some troubleshooting and it appears that whenever the brake pedal is pressed, the AP loses connection the vehicle briefly. It reconnects in a second, but if the brake pedal is still pressed, it instantly loses connection again the process loops, causing the APs screen to "flash". If I try and flash a new map to the ECU, it will always throw a "Accessport cannot communicate with vehicle" message, telling me to ensure the ignition is on. I turn on the ignition, but it will never work, until I press in the brake, let go of the brake, then press OK on the AP and it will then flash no issues. Same thing for making any adjustments like Launch Control. It will fail to apply the change, until I press the brake, let go of the brake, then press OK to apply the setting.
This makes it impossible to view gauges accurately or start data logging, as any time I press the brake while driving (which is a fairly common thing to do while driving) the AP disconnects and resets all gauges and cancels the data log.
I have a video of the problem HERE if anyone wants a visual.
Does anybody have any clues? I'd take it back to the retailer, however I live quite a ways up north from them and was only down for the weekend when I bought it, so I won't be heading back down for another couple weeks at the least.
Thank you,
-Ryan
Thank you,
-Ryan
