1 - 7 of 7 Posts
Help Diagnose this, please! rough idle *videos*
Ok, so the past few days, whenever I start my car, the Rpms will dip to around 200, then "bounce" up to normal idle of around 6-700. It feels like the engine is going to stall. Also, whenever I put my foot on the clutch, the rpm's will do the same, dip down like about to stall, then back to normal. It is really annoying and I am worried about my car.
I did some searching under "rough idle", and figured it may be spark plug misfires or a bad maf sensor. There are no CEL's and I cleaned the maf sensor an hour ago with non-corosive brake cleaner but that did not work. Could it just be the spark plugs?
Vids: -Startup
http://www.beergoggles.org/subaru/rpms start.MOV
-when i put my foot on the clutch
http://www.beergoggles.org/subaru/rpms highway.MOV
^^^ thanks to brianH for hosting
Thanks
-Chris
edit: mods are turboback, uppipe, intercooler hoses, and AccessPort. I have had no problems with these mods in the past 5 months when i got them installed
I'm guessing intake leak. Had any service recently? New air filter? Removed hoses? Cracked y-pipe?
I'm going to put on my stock BOV on tonight, check all of my hoses, and check the the idle control valve. The Y pipe is a Perrin that I've had for the past 1000 miles with no problems. I had just recently put my stock intake on.
I agree, double check all your hoses, and swap the BOV back to stock. In other makes of cars I've seen lazy IAC valves (intake air control) cause this.
ok, first if all it f-ing freezing outside. I swapped my BOV, that wasnt the problem. I checked all of my hoses, making sure they were free, and its still happening. I am getting really fustrated. I'm taking it to my dealer tomorrow.
have the dealer run a diagnostic check for either a bad idle control valve or bad o2 sensors...i had em both on mine and my car ran like crap till the fixed it and all i have on my car is a catback
1 - 7 of 7 Posts
