1 - 5 of 5 Posts
I did the Koji mod to my lights today, in addition I also did the DRL mod. I now have no low beams. Help!! I checked the connections in the light housing, all is well there. Checked fuses, reattached the DRL module by the glove box. ANy ideas what I should do?
does your high beam work??
double check the light harness, and see if the light is securly in ... it is supposed to snap in to place ... reconnect everything you might have disconnected ... also check the fuses inside your car and maybe the fuse for the headlight control lever went out
DUMB, DA DA, DUMB DUMB
Bulbs must have gotten jarred on the re-install. Bought new bulbs, problem solved. Emergency over, go back to what you were doing.
1 - 5 of 5 Posts
