1 - 7 of 7 Posts
is there any way to get the horns to be installed further apart. When you mount them where the stock ones are they are only half showing... any way to make them both spread apart more with a mount of some sort??
Good news, everyone!
You could always fab one up or relocate the stock mounts.
I couldn't figure out how to move the stock mounts because there connected to the bracket that holds the hood shut.
Subiemods sells a mount for the Hellas that makes them a little further apart.Subimods.com Hella Supertone Horns Bracket
I just went to Home depot,got 2 longer brackets for like $4,a couple of bolts & washers,painted the brackets black & mounted the horns on them.
Will that subiemod fit on the 2011?
What kind of brackets are at HD? Got any pics?
Yes the subiemods bracket should fit.
From HD,just some ordinary steel brackets.Like these,only straight,they come in different lengths.Product Information Error Page For one bracket I used the mounting hole for the stock horn.For the other there is a smaller hole right next to it.You may have to make it bigger,but just be careful with a drill there as you are very close to the a/c condenser,or just use a smaller bolt
Sorry,no pics
1 - 7 of 7 Posts
