I installed them a couple of weeks ago, and just got a chance to use them at their first autoX this past weekend.
I had a problem: the left side would only provide about .5 degrees negative camber before the upper spring perch (stock spring) hit the shock tower.
I did not have the same problem on the right side, where I was able to get about -2.5 degree camber.
I will be switching to Ground Control springs very shortly, but I just wanted to give everyone a heads-up and see if anyone else had this problem.
