1 - 9 of 9 Posts
Hey guys
I'm looking to make a list of built engines, swapped engines, what power theyre making and what problems they've had. I started the thread over @ NASIOC but I know some of ya'll don't use NASIOC. I'll put the same list here, and the link to the post there. If you don't mind taking a minute to fill this out, it would probably be a huge help for future engine builders. Thanks! :)
Heres the post--
Hey guys
I've been reading alot of the motor build threads and I'm about a month away from begining my own quest for 400+whp
If you've built a motor (or have a motor that wasn't stock with the car)in an older suby, WRX, sti, whatever.. please take a minute and check in here.
What shortblock? ____________
What heads? ___________
What turbo? ___________
What engine managment? _____________
Fuel modifications? _____________
Cooling Modifications (IC, Radiator, Oil cooler, etc) _________
How many miles? __________
WHP?__________(And what dyno you made this power on, please)
Problems, if any (Or if many) _____________
This might help to clear up some myths, focus on problems, and steer future engine builders in the right direction.
Thanks guys
Scott
http://forums.nasioc.com/forums/showthread.php?postid=5786210#post5786210
oh and btw... here's my setup :)
Stage 4 Axis Power Racing Stroker Motor
- 2.35 Liter Displacement
- Polished & Balanced 2.5 STi Crank
- Pauter 4340 Chrome-Moly Forged Rods
- CP Forged Pistons (9:1 Compression)
- Cometic Head Gaskets
- ARP Head Studs (Over Sized)
Axis Power Racing Cylinder Heads
- Axis Racing Ported STi Spec C Cylinder Heads
- Axis Racing Dual Spring Valvetrain Kit
- JUN 272 Cams
Performance Mods
- Axis Racing Custom 70mm Throttle Body & Adapter Plate
- T60-1 Hybrid T3/T4 Turbonetics Turbocharger
- Custom Axis Racing FMIC & Piping
- Tial External Wastegate
- Custom Up-Pipe
- Spec-C TGVs
- Axis Power Racing Fuel Rails & Braided Line
- Aeromotive Fuel Pressure Regulator
- Aeromotive A1000 Fuel Pump
- Custom Downpipe w/ Vishnu Exhaust
- Electromotive Tec3 ECU
Other Modifications Include
- Built 5 Speed Transmission
- EXEDY Hyper-Twin Plate Clutch
- Brembo Gran-Turismo Big Brake Kit
- Cusco Rear Sway Bar
- Powder coated Intake Manifold
- Painted Valve and Timing Covers (OEM Subaru Paint)
- STi Projector Headlamps
- HKS SSQ Blow-Off Valve
- Battery Relocated to the Trunk
- GReddy Profec B Electronic Boost Controller
- Blitz Turbo Timer
edit - just added a new radiator too... off a touring car... not sure of the brand... running great... funky idle... but it just takes some tweaking... prolly fix it when we tune it... and the dyno graphs are on axis's website :)
Discussion Starter · #5 ·
Only one person has a non stock motor?
Common guys, it takes 2minutes. it's probably just a copy paste for most of you
Scott
- JUN 272 Cams
Performance Mods
- Custom Up-Pipe
- Spec-C TGVs
- Blitz Turbo Timer
bet that costs a pretty penny
Powertrain:
EJ257 shortblock
WRX heads with EJ257 cams and Axis single spring valvesprings
ARP head studs
Cometic head gasket
Modified Stock injectors
Axis fuel system with ported STi Spec C TGV housings
TD05h-20g turbo (Forced Performance)
TurboXS TBE with RFL-Ti
Blitz FMIC
Drivetrain:
STi V7 6spd Suretrac front and LSD center
3.90 ring gear on WRX diff
Thats it for me.
Richard
1 - 9 of 9 Posts
