Probably the worst time to tackle this since it's cold as balls but trying to reduce the cabin noise which is just outrageous in my car. Sounds like when a bus goes over bumps and all the windows rattle.
Recently learned from a thread on NASIOC that the liftgate has adjustable rubber stops, similar to those for the hood. Although adjusting these helps them make contact with the body, it pushes the lower, non adjustable rubber stops further away. If I screw them back in all the way the lower ones still don't make contact.
Could the liftgate need adjusting, or the latch? Plan was to stuff foam in between the trim but I think this needs addressing first and might be enough to eliminate majority of the noise.
Curious if anyone else encountered this issue or can shed some light because I'm a bit confused. Trying to make best use of time since nice weather is all but gone.
