1 - 7 of 7 Posts
Hi guys,
I'm picking up my new 04 WRX tomorrow morning. I'm bought it stock and I'm planning to order some Subaru options and install myself (before doing the aftermarket mods). I was thinking about getting the auto-dim mirror w/compass.
I did a search, but I couldn't find much info on the install. Is it tough to do? How hard is it to get the old mirror off? Any special tools needed?
Thanks
No special tools needed. The old mirrors comes off by rotating it 90 degrees. you will need to take out the map light to acces the harness the mirror plugs into. there is a slot on the lens that you put a small screwdriver in to pop off the lens. The remove the two ? can't remember exactly how many off hand. Then the map light should drop dpwn you will see an extra connector that the mirror plugs into. It's really easy takes me about 10 minutes to install, although I have lots of practice. If you buy the mirrior from the dealer there should be instructions in the box that should answer any additional questions you might have.
Shawn
is there a way to turn the auto dim off on the upgraded mirror? i just ordered one tonight, and like the options on it, but i dont always like the dimming effect if i want to be able to spot coppers on my tail before they get all bright and blinky :D . i know on my monte carlo there was a button i pushed to turn the auto dim off. just wondering. thx
Yes it can be turned off. The compass that also comes with it can be turned off as well. When dimming is active there is a green led lit.
Shawn
also, if the car is in reverse, the auto dim is off as well
hope ur mirror last longer then mine, my dimming function went out at 40k miles, after warranty
1 - 7 of 7 Posts
