1 - 16 of 16 Posts
My WRX has about 1800 miles on it and I noticed that when I push in the clutch and try to get into first it feel rough going in and sometimes won't go. If I put it in 3rd first then first without releasing the clutch it slips in nice and easy. This rough feeling is only when I first push in the clutch and try to shift into either first or second. If I go into another gear first (other then Reverse) it goes nice and smooth. This is also true if I go into first then take it out and put it back in without releasing the clutch. I am new to driving stick and have not had any grinding of any sort and have not been launching hard. I also never downshift to first unless i'm close to stalling out in second.
Anyone else have this problem? Any ideas what might cause it?
FYI: I posted this same question to i-club.
Discussion Starter · #3 · (Edited)
Ok that explains it. This is my first manual and the cars that I learned on had around 200,000+ miles on the car and where really worn in.
Anything I can do to make it easier?
I like the quote in your sig from SpaceBalls!!
Thinking Man's Engine
Just wait until winter time, where because of the thickness of the gear oil and the cold weather, it will be harder to row through gears when the gearbox is cold. For that I'd go with a synthetic gear oil.
If you are having trouble downshifting to 1st while rolling, you need to double clutch.
1. Depress clutch pedal, Shift to neutral, Release clutch pedal.
2. Blip the throttle to a little above the RPM you will be at in 1st.
3. Then QUICKLY: Depress clutch pedal, Shift to first, Release clutch pedal, Get back on the throttle.
If you get the revs right it will go into first like a knife into butter. You can use this technique for downshifting into any gear if you want to make your synchros happy.
aka...the double clutch
Do you really need to do that while at a stoplight though?
Gawd I hope not. I figured he was talking about downshifting.
If he is stopped it should go right into first with no problems. If you are transitioning from an FWD cable or rod shift linkage you might find the effort a little high but it's still easy to get into first.
gryphon said:
Actually, sometimes you do.
Either 1)
Shift to another gear then to first
or
Press the clutch, release, press it again, shift to first.
That's the standard method right there. I think FUNKED1 interpreted as while you're still rolling or something.
Discussion Starter · #12 ·
I'm talking from a dead stop. Heck you can have the car off and push in the clutch and try to get into first and it is hard but if you go to 3rd then 1st it slips right in. I never downshift to 1st unless i'm going less then 5 mph.
I think when I take it in for service i'll ask them and maybe get some sythetic oil put in.
You should NEVER try to put the car in gear with the engine off. Sometimes it's a non-issue, other times, you can mess stuff up.
-Jim
Discussion Starter · #14 ·
I'm not saying i'm releasing the clutch while the car is off. It is fine to go through the gears while it is off how do you think people leave the car in gear. When I take it in for service I'll have them look at it and see if they notice anything. I might upgrade to a short shifter anyhow.
Most people just turn off the engine without putting the car in neutral.
It's OK to slot the shifter in place with the engine off, I just don't recommend it. It's just something my dad always told me. I admit I don't really know why....
-Jim
The reason people leave the car in gear, is if the parking brake fails....the car will be rolling (I've seen it happen in company parking lots)
Leaving it in gear, the force to move the car has to be higher than both the gearbox and the engine.
Automatic transmissions, on the other hand have a special gear lock which locks up the transmission completely, preventing a car from rolling down a hill.
1 - 16 of 16 Posts
