1 - 6 of 6 Posts
I have a 2010really Wrx and got new radiator hoses for it. Is it hard to bleed the radiator after I replace them? I know ls6 motors are very touchy thanks!
Why did you get new radiator hoses? And why isn't the dealer making it good as new since it's under warranty?
You don't bleed the radiator. You bleed the cooling system. And it's as easy as can be.
Burping the system to remove excess air can be a little tricky. Warm the car up with the turbo coolant reservoir cap off. Squeezing the top radiator hose should help force any trapped air out of the system.
I got colored hoses teflon. Nothing is wrong with stock, thus no warranty work needed. :) thanks for the link. its helpful.
just know that your colored hoses will probably need trimmed... and sometimes it looks pretty rough if you don't trim them very well.
1 - 6 of 6 Posts
