1 - 6 of 6 Posts
I know most of us are looking for better handling for those days that we go to the track to autocross or track days. I was recently told of a simple mod and wanted to put it out there to see if anyone has heard of it or done it.
This mod is applied to cars who use camber plates in the front. I guess it could apply to the rear as well. Any way it invloves repositioning the camber plates so that the adjustment is back and forth rather than side to side. You basically are adjusting the caster and not the camber.
Discuss...
ive heard this as well. also ive been comtemplating another way to adjust caster, by simply putting aluminum or steel spacers between the frame are your transverse bushings, esentially an alk for almost no money. i dont plan on putting coilovers on my wrx anytime soon, but i may try out those spacers just for fun if its not too hard.
Matt
Moderating on the run!
w/ camber plates instead of orientating them at 90 degrees to the car (where they are adjusting just camber) you cant them at an angle so you get both (neg camber (inward) and positive caster (rearward))
like so
like so
So would you agree that it is a good mod?:confused:, being that you are the suspension/handling guru:D
if your getting the camber you need, clearly this is the way to go- neg camber + positive caster = win:win
you can't get as much neg camber w/ them canted like this (it will vary plate design to plate design), if your not getting the camber you need then your back to the regular orientation
with the exception of some motorsports setups, most will get plenty of neg camber w/ the plates canted
Full Tein
Anyone running the full Tein strut, spring, set up? I'm thinking about running them on my '07 but not sure if its worth the money. My suspension feels pretty stiff already so i might just go with the spring only just to get that lower center of gravity.
1 - 6 of 6 Posts
