1 - 4 of 4 Posts
are there any ECU issues with an 04 ecu. my car is 100% stock engine wise and im ready to install a gutted stocker up. Also, should u plug the bung or put the sensor in. some peopel on nasoic say leave it in b/c the ecu uses that information
When I was researching this it seems that there is an oddity between how the ECU switches from closed to open loop fueling in 2004. So for that reason I waited until I got a reflash to install my gutted U/P, and I did use the resistor instead of the EGT probe.
I have a catless PDE uppipe that is Ceramic Coated and I did nothing with the sensor and have had no problems.
did u notice the increased power much, and u put the sensor in, or plugged the hole, if it had one, i don't know
1 - 4 of 4 Posts
