GSC Power Division AVCS cams for the 2004-2007 STi
Two stage setups to choose from!
STAGE 1: GSC's S1 STi AVCS camshaft set is designed for the stock turbo all the way to a GT30R. The horsepower range for the GSC Stage 1 camshaft set is 350-500whp. GSC STi Stage 1 can set takes advantage of low end spool and increases mid and high RPM tq and hp. truly an awesome set of camshafts for a bolt on equipped STi.
GSC STAGE 1 CAMSHAFTS SPECS:
Intake: 266 / 222 @ .050" / Peak Lift 10.2MM / Centerline AVCS
Exhaust: 266 / 222 @ .050" / Peak Lift 10.2mm / Centerline 113
STAGE 2:GSC's S2 STi AVCS camshaft set is designed for those running a larger turbo than a GT30R. Stage 2 cams are great for STi owners running a GT35R turbo with a HP range of 450-700, on a built 2.5L or stroker to 2.7L block. GSC Stage 2 AVCS camshafts are not full-on drag racing cams; they spool very early and have a power band of 3500-8500rpms.
GSC STAGE 2 CAMSHAFTS SPECS:
Intake 272 / 226 @ .050" / Peak Lift 10.5MM / Centerline AVCS
Exhaust 272 / 234 @ .050" / Peak Lift 10.2mm / Centerline 113
As always JSC Speed is offering special pricing for ClubWRX members! PM, post, or e-mail Aaron for more information.
