1 - 8 of 8 Posts
Does anyone know where i can get a WRX dyno graph? It needs to be a stock WRX... Please let me know! a big reward is promised.
out,
-Jae-
Discussion Starter · #4 ·
Remember that every dyno reads differently. If you want to compare graphs, you need to at least compare graphs from same model dyno, if not from the exact same dyno.
i know there is a graph at car-stats.com but i dont think it's a dyno..i'm not certain check it out
Re: Re: think I found one or two
Jtek said:
That first link CANT be right?!?! the WRX has 215 hp @ the wheel and 246 lb feet of torque?!?!?!?! :confused:
'those are crank numbers, they used a coast down method to determine parasitic loss for the tranny and wheels.
torque still looks a little high, but the hp is right on, b/c they do the tests in 3rd gear only. you'll find that extra 10hp in the upper gears.
dR
1 - 8 of 8 Posts
